Zeitlich begrenzter Rabatt auf alle Fairphone 4 Modelle, gültig bis zum 19. Juni. Es gelten die AGB.
Fairphone 4 Protective Soft Case Grey
Just in case… we’ve got you covered! We’re on a mission to help your Fairphone 4 last as long as possible! This form-fitting protective case is made from 100% recycled material and provides extra comfort, durability and style.
39,95 €
Exklusive Versandkosten.
We're sorry, that's not possible right now
It's not possible to order more than one Fairphone device when you purchase a Fairphone Easy subsciription. This is a technical limitation, and it's totally on us - sorry about that.
First, complete your Fairphone Easy order. Afterwards, create a separate order for the other device or additional subscription.
  • 2 – 5 Tage Lieferzeit
Purpose-built with longevity in mind, the Fairphone 4 Protective Case provides extra durability and a sleek, responsive design.
It’s slim, lightweight and soft, yet sturdy enough to survive unexpected drops. Made from non-toxic 100% pre-consumer recycled material, it wraps carefully around the edges of your screen, absorbing shocks for maximum protection.
With precise cutouts and responsive button covers, this subtly designed case is purpose-built to help your Fairphone 4 last even longer.
Weitere Informationen
Kompatibilität Compatible with Fairphone 4 | Incompatible with Fairphone 3+, Fairphone 3, Fairphone 2, Fairphone 1
Rücksendungen 14-day free returns
Garantie 2-year warranty
Farbe Grey, Green or Red
Höhe 166 mm
Breite 80 mm
Tiefe 13 mm
Gewicht 30 g
Lieferumfang Fairphone 4 Protective Soft Case
