Fairphone 2 Bottom Module
The Fairphone 2 Bottom Modules are permanently sold out. We offer Refurbished Fairphone 2 Bottom Modules, which can be replaced via our repair center. Keep in mind that the costs for this repair are not covered by the manufacturing warranty and would require sending your device to our repair center.
If you are interested in a Fairphone 2 Refurbished Bottom Module repair, please contact our Customer Support team to organize this process for you.
This is a limited offer, until stock lasts.
Excluding shipping costs
We're sorry, that's not possible right now
It's not possible to order more than one Fairphone device when you purchase a Fairphone Easy subsciription. This is a technical limitation, and it's totally on us - sorry about that.
First, complete your Fairphone Easy order. Afterwards, create a separate order for the other device or additional subscription.
Discontinued
The bottom module contains the speaker, vibration motor, USB connector and primary microphone of your Fairphone 2. Share your music across the room with built-in, rear-facing speakers. All components are clearly labeled.
You can easily replace this module yourself using a standard Phillips #0 screwdriver, size PH0. This module is marked as FP-SPK01.
Compatibility | Compatible with Fairphone 2 |
