Fairphone 4 Protective Soft Case Grey
Just in case… we’ve got you covered! We’re on a mission to help your Fairphone 4 last as long as possible! This form-fitting protective case is made from 100% recycled material and provides extra comfort, durability and style.
Excluding shipping costs
We're sorry, that's not possible right now
It's not possible to order more than one Fairphone device when you purchase a Fairphone Easy subsciription. This is a technical limitation, and it's totally on us - sorry about that.
First, complete your Fairphone Easy order. Afterwards, create a separate order for the other device or additional subscription.
Purpose-built with longevity in mind, the Fairphone 4 Protective Case provides extra durability and a sleek, responsive design.
It’s slim, lightweight and soft, yet sturdy enough to survive unexpected drops. Made from non-toxic 100% pre-consumer recycled material, it wraps carefully around the edges of your screen, absorbing shocks for maximum protection.
With precise cutouts and responsive button covers, this subtly designed case is purpose-built to help your Fairphone 4 last even longer.
Compatibility | Compatible with Fairphone 4 | Incompatible with Fairphone 3+, Fairphone 3, Fairphone 2, Fairphone 1 |
Returns | 14-day free returns |
Warranty | 2-year warranty |
Color | Grey, Green or Red |
Length | 166 mm |
Width | 80 mm |
Thickness | 13 mm |
Weight | 30 g |
What is in the box | Fairphone 4 Protective Soft Case |
