Fairphone 4 Screen Protector with privacy filter
We keep saying it: the most sustainable phone is the one that lasts. While the Fairphone 4 display is already tough by itself, this 9h tempered glass screen protector gives it an extra layer of durability, literally.
€32.95
Excluding shipping costs
We're sorry, that's not possible right now
It's not possible to order more than one Fairphone device when you purchase a Fairphone Easy subsciription. This is a technical limitation, and it's totally on us - sorry about that.
First, complete your Fairphone Easy order. Afterwards, create a separate order for the other device or additional subscription.
  • Delivered within 2 - 5 days
We're on a mission to help your Fairphone 4 last as long as possible! Our screen protectors are designed to do just that. The 9H tempered glass is highly durable, providing excellent scratch resistance and even protecting against low-level drops. A special surface coating reduces fingerprints, and the curved edges round out the discrete design. Our screen protectors come in two filter-versions (blue light & privacy); both are easy to apply and remove.
Our privacy screen protector serves double duty to keep your display in pristine condition while also ensuring that no one can sneak a peek on your screen. Super-spy type stuff.
Made from Accessory Glass by Corning® material.
More Information
Compatibility Compatible with Fairphone 4 | Incompatible with Fairphone 3+, Fairphone 3, Fairphone 2, Fairphone 1
Returns 14-day free returns
Warranty 2-year warranty
Length 155 mm
Width 70 mm
Thickness 1 mm
Weight 12 g
What is in the box Fairphone 4 Screen Protector with privacy filter, Glue back and Installation Set (microfiber cloth, alcohol pad)
