USB-C 3.2 Long Life Cable
Never worry about charging cables again. The Fairphone USB-C 3.2 Long Life Cable holds true to its name.
One cable to charge them all: Multipurpose adapter included.
Lasts a lifetime: Designed for ultimate durability.
Blazing fast sync speeds: Transfer your data with up to 10 Gbps.
€34.95
Excluding shipping costs
  • Delivered within 2 - 5 days
This lifetime-lasting, multi-purpose USB-C 3.2 cable is reinforced with braided kevlar and nylon for exceptional durability and is designed to withstand the toughest industrial-grade stress tests (You can twist it over 50.000 times and it will keep on going). The strain relief is made from bio TPU and there’s a handy velcro-organizer attached.
The cable has futureproof C-to-C connectors and comes with the flexibility of a USB-C to USB-A adapter. It gives you the latest performance of supporting 3A and transfer speeds up to 10 Gbps, for example between your laptop and a portable hard drive. Never worry about charging cables again and cut down on e-waste with the cable that’s designed for true longevity.
  • Charging and data cable
    • USB-C to USB-C
    • USB-C to USB-A with adapter
  • USB 3.2 Gen 2x1 standard
As Fairphone 3 and Fairphone 3+ charge at 5V, you cannot experience the full performance of this charging cable. Your phone will experience a maximum of 15W charging performance.
More Information
Compatibility Compatible with Fairphone 4, Fairphone 3 and Fairphone 3+ | Incompatible with Fairphone 1 and Fairphone 2
Returns 14-day free returns
Warranty 2-year warranty
Color Braided black and yellow
Length 120cm
Weight 63.9gr
What is in the box This item includes one piece of cable with C-to-C connectors and a C-to-A adapter. A velcro with the Fairphone logo is attached to the cable as a cable organizer
