USB-A 18W Charger (UK)
While the Fairphone 3 battery lasts a full day on average, sometimes your days call for a bit of extra power. Using the Fairphone USB Charger, your battery charges much faster than with a regular charger, so you’re ready to go in no time!
Technical specifications
  • Model: DBS15QB
  • Qualcomm Quick Charge 3.0
  • Input: 100-240V~50/60Hz 0.5A
  • Output: 5.0V 𝌂 3.0A/9.0V 𝌂 2.0A/12.0V 𝌂 1.5A 18.0W MAX
  • Average active efficiency: 82.6%
  • Efficiency at low load (10%): 78.8%
  • No-load power consumption: 0.04W
  • Efficiency level: VI
  • Color: black
Please note: the USB-C 3.2 Long Life Cable is sold separately
Compatible with Fairphone 3, Fairphone 3+ and Fairphone 4.
€19.95
Excluding shipping costs
We're sorry, that's not possible right now
It's not possible to order more than one Fairphone device when you purchase a Fairphone Easy subsciription. This is a technical limitation, and it's totally on us - sorry about that.
First, complete your Fairphone Easy order. Afterwards, create a separate order for the other device or additional subscription.
  • Delivered within 2 - 5 days
