EXCELLENT
10IFIXIT
iFixit score: 10 out of 10
10/10
Fairphone 4 teardown
Everything that makes Fairphone 4 a great choice, now with added privacy. This Fairphone 4 (Grey, 128GB) runs on the open-source "/e/OS" operating system. Add the 5G speed, a 5-year warranty and our commitment to people & planet and you've got the real deal.
Making the fair choice has never been easier. Premium dual cameras with AI scene detection. Long battery life. Modular design with eight swappable spare parts. Crafted with fair and recycled focus materials. Five-year warranty and extended support till 2028. This is fairness at its core.
Standard Google apps are pre-installed like Google Maps, Chrome and Gmail
Support from the Fairphone Customer Support team
Choose from all Fairphone 4 colours including Grey, Green and Speckled Green
Choose how much storage you need, 128GB, 6GB RAM or 256GB, 8GB RAM
A set of carefully selected, /e/OS default apps. You choose which additional apps you install. /e/OS is Android™ app compatible
Support from the Murena team, the creators of /e/OS
Fairphone 4 with /e/OS is available in Grey
Fairphone 4 with /e/OS storage is 128GB, 6GB RAM
Android is a trademark of Google LLC
Buy a Fairphone 4 and join the movement.
Your phone was made to be enjoyed. With a speedy processor, expandable storage and great battery life, the Fairphone 4 is ready for anything.
Robust design built with care and quality. With easy access to customer support and modular parts, your phone will remain by your side.
Keeping your phone for 5 years cuts CO2 emissions by 31%. Which is why we include long-term support and software updates backed with a 5-year warranty.
The carefully selected set of default open-source apps provide for your daily digital needs, and keeps your data private. With its speedy processor, large amount of expandable storage and great battery life, the Fairphone 4 is built for your lifestyle.
5G to match your pace. Video call your friends in HD. Stream high-quality music. Download on the go. But there’s no rush, really. Get started with your existing SIM card and switch over when you’re ready.
An immersive 6.3inch Full HD+ display that reflects all your needs. High quality encased in a smooth aluminium body and soft, recycled back cover. It looks good and feels great.
Our dual camera 48 MP system captures every moment. In detail. Ultra-wide. In high-def, and at night. With 4k video resolution. Inspiring memories and creating new ones.
When you buy a Fairphone 4, we recycle or give one old phone a second life. This means 100% compensation for the material we put into the market. Making it e-waste neutral. And something you and the industry can get behind.
The Fairphone 4’s body is built from aluminium. And we know where it came from. From end-to-end. To top it off, we’ve designed it with a 100% recycled plastic back cover. Using fairer materials as much as possible.
All the parts in the Fairphone 4 come together in perfect harmony because people made it that way. People with interests, hobbies, and full lives. With each Fairphone 4, we reserve a living wage bonus for the people that made it.
You don’t need to be an expert to swap out the battery or display. No part of Fairphone 4 is glued shut, so you can choose to easily repair it yourself.
Cameras, like a picture, should be long-lasting. Our main camera and selfie camera are replaceable.
What else is long-lasting?
Fairphone works with the camera supplier to ensure safe working conditions and improve worker voice and satisfaction.
The USB-C port is the unsung hero of our devices. It's used daily to charge our phones or transfer our data. That can take a toll. But there's no need to call it quits. All our USB-C ports are fully replaceable. Simple and easy, just as it should be.
The back cover is what you hold onto the most. Made with 100% recycled plastics, the Fairphone 4 goes the extra mile to bring you closer to sustainability. And it feels great.
The loudspeaker was made by many hands. So we work with the speaker supplier to ensure safe working conditions and improve worker voice and satisfaction. Everyone deserves a voice.
We have updated the camera software to improve your imaging experience. Near-zero shutter lag, faster autofocus, smoother video stabilisation; your photos and videos have never looked better. See for yourself!
The dual 48MP rear cameras have been upgraded in 2024 for faster and better photos.
Focus in on the action.
Capture every detail.
48MP Ultra Wide lens and f/2.2 aperature 120° field of view
The upgraded camera experience makes low-light performance even better than before.
In brightest day
In darkest night
Fairphone 4 is packed with future-proof specs.
/e/OS More Info
162 x 75,5 x 10,5 mm
Qualcomm Snapdragon 750G (SM7225)
6GB - 128GB internal storage
External storage capacity: microSD up to 2TB (SD 3.0)
3905 mAh removable Li-ion battery
6.3 inch Full HD+
Dual 48MP rear cameras - F1.6 and 2.2
25MP selfie camera - F/2.2 with HDR support
Primary Camera - OIS Camera
Sub Camera - Ultra-Wide
Selfie Camera
Wi-Fi dual band (2.4 GHz + 5 GHz) - Bluetooth 5.1 + LE
NFC for card payments & more
Dual SIM, both 5G enabled
(One physical Nano-SIM slot (4FF), 5G enabled* and One eSIM, 5G enabled*)
* Only one SIM card slot can be active on 5G radio technology at a time
5G
4G
3G
2G (GMS, GPRS, EDGE)
USB Type - C
Fingerprint scanner
USB Type C
Supported audio-codecs
Supported video-codecs
Unique modular design with IP54
TCO Certified
6GB RAM and 128 GB internal storage Color: Grey
Is your phone lying in a drawer somewhere? Why not put it to work? It’s worth it.
Everything you need to get started. No more. No less.
We do not include a USB Cable, charger and audio jack adapter in this box because we believe that it’s better to save the environment through the reduction of plastic waste. Of course, it’s possible to buy one of these products if you need it.
We sell Fairphone with /e/OS only in the European Economic Area (EEA). European countries that are not in the EEA, and therefore that we do not ship to are Monaco and San Marino.
There are no standard Google Apps on Fairphone 4 with /e/OS. However, /e/OS comes with equivalent, open-source apps to cover your common needs, both personal and professional. There’s a maps app, a web browser app, a calendar app and many more, so you can check your email, plan your week ahead, chat with your friends and coworkers, browse the web, check the weather, check your itinerary for your next meeting.
/e/OS is still compatible with all your favourite Android apps, because keeping your data private shouldn’t mean forgoing your digital experience. You can choose to download them yourself from Murena’s AppLounge.
You would need to contact
Murena as they handle the customer support for Fairphone 4 with /e/OS.
Yes, you will be able to receive the 5 year warranty for your Fairphone 4 with /e/OS.
Yes, you could receive support from Fairphone if you change the software back to Android.
If you’d prefer, you can buy the Fairphone 4 with Android as the OS and install /e/OS yourself, for free. You can do this using
Murena’s easy installer, a software application compatible with Windows, Linux and MacOS that will help install /e/OS on your phone following simple steps on your screen, or their command-line for more advanced users.
The benefit of buying it from our website is that the phone is already flashed.
Yours to open, yours to own. That’s your phone. Because it’s not glued shut, you can know all of the parts in order to take care of it. Repair it. Even upgrade it.
Finally a mobile phone company that wants to take a step in the right direction. A top company that is really committed to making the world a little better within the possibilities that are realistic.
You can either buy Fairphone 4 with /e/OS by Murena through our website, or on Murena’s website.
Do you have any questions about our Fairphone or about our products?
There are more phones than people. And behind every device is a complex supply chain. With suppliers, local communities and the wider industry, we work for fairer materials and more responsible practices. Showing the electronics industry that we can do better.
Together we’re disrupting the industry’s short-term thinking that the world can no longer afford. And changing what it means to be “best.”
