For TWS
Fairphone TWS Left Replacement Earbud
Lost or broke one of your Earbuds, but still have two ears? We've got you covered with the Left Earbud.
€44.95 -0%
Or pay in 6 terms with
Out of stock Coming soon. Be the first to know when it's available Coming soon buy now notify me We'll keep you posted notify me Delivery: 2 - 7 days (from €3.95) Find a store
Out of stock
This item is out of stock
Invalid email address
notify me
Fairphone TWS Left Replacement Earbud is coming soon.
notify me
Description
Products should be made to last. Even if you lose it or break it. But just because you've lost one of your Earbuds, it doesn't mean it has to be the end of your enjoyment. Luckily, we've got you covered with an identical replacement for your lost or damaged Left Earbud.
It's only compatible with your True Wireless Stereo Earbud set, but it still has the same high sound quality, comfort (medium tip), and active noise canceling. And if you really want, you can mix and match the colors. For a fraction of the whole set price. Good for the planet and easy on the wallet.
When you get your replacement earbud, you will have to reset the set.
Look for instructions on how to do it on our support page.
Technical specifications
Compatibility
Compatible with True Wireless Stereo Earbuds only.
Product dimensions
Length: 35mm
Width: 15mm
Thickness: 25mm
Weight: 5g
Color
Grey, Green, or Black
What is in the box
Fairphone True Wireless Stereo Left Replacement Earbud with a medium-sized tip.
Zie meer specificaties
