BUY
choose a section
Fairbuds
27016 Reviews
Fairphone Reviews
EXCELLENT
4.3
score based on 27016 reviews
5-star
68%
18368 of 27016 reviews
4-star
15%
4043 of 27016 reviews
3-star
6%
1581 of 27016 reviews
2-star
4%
956 of 27016 reviews
1-star
8%
2068 of 27016 reviews
  • All Languages
  • English
  • Deutsch
  • Français
  • Nederlands
  • Most recent
  • Oldest
  • Titanium coated 11mm drivers
  • Active Noise Cancellation with advanced wind reduction
  • Modular and easy to repair with replaceable buds and batteries
€99
BUY NOW Try risk-free for 14 days Find a store
Fine-tuned just right
Jump to sound
Bold sound. Built to last.
See why
Active Noise Cancelling
Your sound. Uninterrupted.
Premium sound
  • Active Noise Canceling
    Immerse yourself in your music. Or stay connected to the world around you. It's up to you.
  • Titanium drivers
    Experience rich, perfectly balanced sound with titanium-coated 11mm premium drivers.
  • Seamless dual point connectivity
    Stay connected to multiple devices simultaneously and switch between them hassle-free.
  • Dedicated app for iOS and Android
    Pick your favorite presets, customize EQ settings just how you like it, and get all the latest software updates.
26h
of listening
6h earbud + 20h charging case
Get up to 6 hours of listening on one charge, plus 20 more with the charging case.
For pristine sound in less than perfect conditions, switch on ANC with advanced wind reduction.
Crystal Clear Calls Always
Crystal-clear calls and voice recordings, powered by Environmental Noise Canceling (ENC) and six mics to cut the noise.
Built to last
Designed for living worry-free
  • Three-year warranty
    Your Fairbuds come with a 2-year warranty, now with an extra year on us – because we’ve got you.
  • Easily repairable
    True wireless earbuds, reimagined by Fairphone – built to last and repairable.
  • Replaceable batteries
    Fairbuds are built to keep going, with replaceable batteries in each bud and the charging case.
  • IP54 Sweat and water resistance
    It’s always raining in Amsterdam, so we made them weatherproof – perfect for workouts, too.
iFixit
10 / 10
Easy to use.
Easy to control.
Get the perfect fit
Because one size shouldn’t fit all. Choose from three different ear tip options and find the one that fits the best.
Connect to more devices
Connect to multiple devices and let the Fairbuds do the work for you. The Fairbuds will know where the music is playing, so you can sit back and enjoy.
Auto play and pause
The Fairbuds know when they're in your ear. Take them out and your song will pause, put them back in and you won't miss a beat.
Dual audio controls
Control your favorite playlist straight from your Fairbuds. Adjusting the volume and playback is right at your fingertips.
Impact Innovation
Designed with purpose
Small size. Big impact.
Made with fair and recycled materials
We account for the gold, silver and cobalt in the Fairbuds by investing in in credits that improve working conditions at the mines. They’re also made with recycled rare earth elements and recycled plastics.
Made in fair factories
Fairbuds come with a living wage bonus for the people who make them. We go further to ensure they’re treated fairly, paid well, and can take pride in their craftsmanship.
Electronic waste neutral
Your Fairbuds are e-waste neutral – for every pair sold, we responsibly recycle an equal amount of electronic waste.
Climate conscious
The most CO2-intensive part of making earbuds is in production. So we’re designing our Fairbuds to last, using recycled materials, and supporting CO2-reducing projects. It’s our way of stepping up for the planet.
The specs at a glance
The Fairbuds are made for all your listening and wireless needs.
Controls
Capacitive Touch Controls (Both Earbuds)
Bluetooth & wireless
Bluetooth: v5.3 (Profiles A2DP V1.2, AVRCP V1.5, HFP V1.8, HSP V1.2;)
Multipoint Connection (Dual)
Codec: SBC & AAC
Wireless Range: up to 10M (line of sight)
Connectors & charging
USB Type-C
Battery
Battery capacity: 45mAh (earbuds) 500mAh (charging case)
Number of cycles: >500 cycles
Charging time: ~2 hours (case + earbuds), 10 min for 1.5h playback
Total playtime (with case): Up to 26 hours
Calling / Music time: Up to 5 hours (ANC on)/ Up to 6 hours (ANC off)
Wireless charging: No
Replaceable battery: Yes (both earbuds and case)
Sound
Driver Diameter: 11mm
Driver type: Titanium coated, dynamic driver
Sensitivity: 104±1dB at 1KHZ
Frequency Response Range: 20Hz -20KHz
Driver impedance: 16Ω ±15%
Microphone
Total of 6 mics: 3 left, 3 right
Smart assistants: Google Assistant, Apple Siri
Weather resistance
Earbuds: IP54 rating (light rain and sweat)
Case: no IP rating
Product dimensions
Earbud: 28.7mm*24.6mm*21mm
Case: 65mm*65mm*27mm
Weight: 82g including case; earbuds ~5g
Compatibility
Compatible with Fairphone 3, 3+, 4 and 5
Compatible with any device with Bluetooth
See more specifications
Included in the box
Everything you need to get started. No more. No less.
  • Fairbuds and charging case
  • Three pairs of ear tips
  • Quick-start guide
Fairbuds
Black
White
0.00 €249
Frequently asked questions
Why have you launched the Fairbuds?
Our mission at Fairphone is to establish a viable market for sustainable consumer electronics. Many of the problems that we see with smartphones, especially around e-waste and issues in the supply chain, also apply to audio products. In 2021, the Fairphone TWS earbuds were our first step into this new product category. They incorporated longer battery life and Fairtrade gold in the supply chain, but were, otherwise, an off-the-shelf design that was not repairable. Our plan was therefore always to improve on the design later on. The Fairbuds are the result of these efforts.
How do I use my Fairbuds?
We have a dedicated support article. Click here to go check it out.
What warranty do you offer on the Fairbuds?
There is a standard 2-year warranty on the earbuds, plus a one-year extended warranty if users register their Fairbuds online. That said, due to the modular design and the repairability, we expect the Fairbuds to last a lot longer than three years.
Which parts of the Fairbuds can be repaired or exchanged by the user?
Earbud (Left and/or Right). Earbud Battery and Silicon Ring. Earbud Tips. Charging Case Outer Shell. Charging Case Core. Charging Case Battery.
Are the Fairbuds water-resistant/waterproof?
The Fairbuds have IP54 certification, meaning they are sweat and weather resistant, but not completely waterproof.
What is the Fairbuds app used for?
The Fairbuds app offers users more control over their earbuds, allowing you to change equalizer presets and tune your Fairbuds to your personal preferences. You can use the app to access the latest Fairbuds updates as well, ensuring better longevity of your device, with potentially new features, and the occasional bug-fix. The app also offers users a quick start guide, tutorials, support articles and a customer service touchpoint. Learn more about the different components that make up your Fairbuds, and order replacement parts through the app if your Fairbuds are in need of repairs.
Prefer the in-store experience?
We’re in stores near you—find the closest one.
STORE LOCATOR
