Adapter USB-C to Mini-jack
Not ready to cut the cord yet? Keep your wired headphones plugged in with our new USB-C Mini-jack Adapter.
€7.96 €9.95 -20.0%
Or pay in 6 terms with
Out of stock
This item is out of stock
Invalid email address
notify me
Adapter USB-C to Mini-jack is coming soon.
notify me
USB-C Port
Just connect the adaptor to the USB-C port, then plug in your wired headphones and press play.
Dac chip connection
It includes a DAC (Digital to Analog Convertor) chip. Allowing easy connection.
Audio jacks
Compatible with TRS and TRRS audio jacks. It's capable of both audio input and output.
Description
Keep your wired headphones for longer. While The Fairphone (Gen. 6), Fairphone 5 and Fairphone 4 do not have a regular 3.5 mm headphone jack, that doesn’t mean you have to throw away your wired headphones. If you want to stay wired, we’ve got you covered with the UBS-C to mini audio jack. As long as you have a USB-C port, you can use this adaptor.
This adaptor is compatible with both TRS and TRRS jacks. When it comes to TRRS, it’s suitable for both CTIA and OMTP. To put it in simpler terms, it can be used for audio input as well as output. Enabling the use of headsets with microphones or a standalone microphone.
Just to be sure: Your Fairphone 3 or 3+ already came equipped with a 3.5mm headphone jack. So, there’s no need for an adaptor. If you have a Fairphone 1 or 2, unfortunately, neither phone is compatible with this adaptor. Just keep and use what you do have.
And the best part? This cable is able to withstand bending 25000 times!
Technical specifications
Compatibility
Compatible with Fairphone 5 and 4. Or any phone with a USB-C port.
Product dimensions
Length: 123mm
Width: 11.3mm
Thickness: 8mm
Weight: 4g​
Color
Black
Sampling rate
Up to 16 bit 192Khz or 24 bit 96Khz
Signal to noise ratio (SNR)
116dB FS
Impedance
4-32 Ω
What is in the box
Only the USB-C to Mini Audio Jack Adaptor. We like to minimize waste.
See more specifications
