Fairphone 4 Battery
The original Fairphone 4 battery combines all-day power (3905mAh) and fast-charging with our dedication to integrate fair cobalt and responsible lithium into the supply chain.
€29.95
Excluding shipping costs
We're sorry, that's not possible right now
It's not possible to order more than one Fairphone device when you purchase a Fairphone Easy subsciription. This is a technical limitation, and it's totally on us - sorry about that.
First, complete your Fairphone Easy order. Afterwards, create a separate order for the other device or additional subscription.
  • Delivered within 2 - 5 days
The original Fairphone 4 battery has a lot going for it. It reliably keeps your phone up and running all day long. It comes with convenient fast-charging technology that jumpstarts you back to 50% of its 3905mAh capacity in half an hour (when using chargers with a 20W minimum).
And it’s probably the world’s easiest and fastest spare part replacement. When the time comes to replace your battery, you don’t have to be an expert to swap it out in only a few seconds.
But wait, there’s more than meets the eye. Behind the scenes, we’re innovating where it counts: We’re working with the Fair Cobalt Alliance to integrate fair cobalt and responsible lithium into the supply chain.
About as fair as they come!
Pro-tip: Works great as a spare-battery too, if you’re on the go and need to double your battery-life.
The battery will keep 90% of its original capacity after being charged 547 times (full cycles). Nominal capacity: 3905 mAh/15.03Wh. Nominal voltage: 3.85V
More Information
Compatibility Compatible with Fairphone 4 | Incompatible with Fairphone 3+, Fairphone 3, Fairphone 2, Fairphone 1
Returns 14-day free returns
Warranty 2-year warranty
Length 91.9 mm
Width 46.8 mm
Thickness 6.2 mm
Weight 63.7 g
What is in the box Battery, Health and Safety Guide
