EXCELLENT
Based on
-- reviews
Checkout as guest-- of -- reviews
-- of -- reviews
-- of -- reviews
-- of -- reviews
-- of -- reviews
Not ready to cut the cord yet? Keep your wired headphones plugged in with our new USB-C Mini-jack Adapter.
This email is not a valid email address. Please, add a valid email address.
Just connect the adaptor to the USB-C port, then plug in your wired headphones and press play.
It includes a DAC (Digital to Analog Convertor) chip. Allowing easy connection.
Compatible with TRS and TRRS audio jacks. It's capable of both audio input and output.
Use it for your Fairphone 5 and 4. Or any phone with a USB-C port and no headphone jack.
Specs of the Fairphone 4 Selfie Camera
Compatible with Fairphone 5 and 4. Or any phone with a USB-C port.
Black
Up to 16 bit 192Khz or 24 bit 96Khz
116 dB FS
4-32 Ω
Only the USB-C to Mini Audio Jack Adaptor. We like to minimize waste.
Keep your wired headphones for longer. While our Fairphone 5 and Fairphone 4 do not have a regular 3.5 mm headphone jack, that doesn’t mean you have to throw away
your wired headphones. If you want to stay wired, we’ve got you covered with the UBS-C to mini audio jack. As long as you have a USB-C port, you can
use this adaptor.
This adaptor is compatible with both TRS and TRRS jacks. When it comes to TRRS, it’s suitable for both CTIA and OMTP. To put
it in simpler terms, it can be used for audio input as well as output. Enabling the use of headsets with microphones or a standalone microphone.
Just to be sure: Your Fairphone 3 or 3+ already came equipped with a 3.5mm headphone jack. So, there’s no need for an adaptor. If you have a
Fairphone 1 or 2, unfortunately, neither phone is compatible with this adaptor. Just keep and use what you do have.
And the best part? This cable is able to withstand bending 25000 times!
-- REVIEWS
