choose a section
ANGEBOT
Fairbuds XL Headphones
392 Reviews
Fairbuds XL Headphones Reviews
Die gezeigten Bewertungen umfassen Erfahrungen mit den Fairbuds XL (2023) und dem neuen Fairbuds XL Modell (2025).
EXCELLENT
4.5
score based on -- reviews
5-star
71%
277 of 392 reviews
4-star
19%
73 of 392 reviews
3-star
6%
22 of 392 reviews
2-star
3%
12 of 392 reviews
1-star
2%
8 of 392 reviews
Verified
More details
Fewer details
Jan 6, 2026
I really like their design and the sound quality has been top notch. The buttons are also incredibly easy to get used too contrary to my expectation. Truly the only flaw I find in them is how tightly they fit around my ears, they end up pressing my glasses against my skull so much to the point it starts hurting after a few minutes. Using them at a slight angle helps though I would love to see some design improvements made in terms of adjustability.
Verified
More details
Fewer details
Jan 5, 2026
Excellent headphones! Very good sound quality and battery life. Very comfortable to wear, although when I lean forward/downward, they slip a bit in my head. (But I think this is a small head exclusive problem only.) The repairability is a huge bonus.
Verified
More details
Fewer details
Jan 1, 2026
My Fairbuds XL are great. Great sound, noise cancelling and ambience sound. I am very pleased with them so far.
Verified
More details
Fewer details
Dec 30, 2025
Absolutely lovely headphones, Sound and material choice are fantastic. My only issue is the earcups are not deep enough for my ears! Would love a purchasable set that are deeper, Only by like 5mm or so. I can still wear them just fine but can feel the inside drum bit ever so slightly. Would highly recommend them regardless as everybody's ears are different :-)
Verified
More details
Fewer details
Dec 28, 2025
Poor passive noise control, although they sit tight (perhaps a little too tight). Poor ANC quality overall, especially noticeable in the low frequencies. Audio quality no surprise. XLs keep disconnecting randomly, reconnect is mostly too slow for phoning. But I like the design materials, and I find the orange cable – and the repairability argument – rather nifty.
Answer from Fairphone
Hello, we really appreciate the feedback to help us improve your experience. We’ll make sure to pass your feedback along to our team. Best, Diego
Verified
More details
Fewer details
Dec 26, 2025
bought as present, and ecceded expectations, only minus is lack of email comunication (information about package delivery date) because system fallout before chrismas
Verified
More details
Fewer details
Dec 26, 2025
Good. But then YOU CAN UPGRADE IT with 2025 drivers and else. Thus I grant an extra star. And I see a clear purchase path here.
Verified
More details
Fewer details
Oct 26, 2025
Very comfortable to wear and easy to set up and use. I’ve used them for running too and they work well.
Verified
More details
Fewer details
Oct 26, 2025
better quality & better feel than I expected. controls are really intuitive. Almost looking forward to having to replace a part but i dont feel that is going to happen any time soon
Verified
More details
Fewer details
Oct 26, 2025
The ANC works in most cases but wind affects it in the same way as the normal microphones used for telephone calls. These microphones do also work well, the aspect that rates them down a bit is that the surrounding can be heard by the other person in the call. Over all the headphones work well, with some little problems Fairphone maybe should fix.
Verified
More details
Fewer details
Oct 17, 2025
Very capable headphones, the noise cancellation is adequate for my needs and the EQ provided by the app is a very nice addition. Very satisfied with purchase, and especially the ability to easily change earpads and availability of spare parts
Verified
More details
Fewer details
Oct 6, 2025
Especially batteries are looong. In a sound quality i have no how to compare
Verified
More details
Fewer details
Sep 27, 2025
Battery life is good, quick-start guide and app are helpful when initially setting up, the noise-cancelling seems to work pretty well. The only potential issue is that sometimes the joystick will think I'm selecting front to back instead of up and down. But that's pretty rare. And they seem to work with any kind of device, which is lovely. The sound notifications to let you know you've turned your headphones on or off as well as switching between noise cancelling settings is very handy
Verified
More details
Fewer details
Sep 22, 2025
Great quality product, I'm very happy with it, easy to set up and great sound too!
Verified
More details
Fewer details
Sep 12, 2025
Great product. Disappointed i missed out on the sale by a few weeks it would have saved me a few euro.
Verified
More details
Fewer details
Sep 2, 2025
Physically broke after a few days, no reply from my support ticket.
Hello Christian, thanks very much for bringing this to our attention. We’re so sorry to hear about your experience & the wait you're having with our response, we're experiencing busier times on our end. We can see you already created a support request, and our Support Team is currently helping with your case. Best, Laura
Verified
More details
Fewer details
Aug 22, 2025
Very comfortable, easy to use, great battery life.
Verified
More details
Fewer details
Aug 2, 2025
lightweight and fitting headphones. Powerful and steady bluetooth. Stylish layout. Clear talks and great audio.
Verified
More details
Fewer details
Jul 28, 2025
These have exceeded my expectations. I bought them because they are sustainable, but actually the design is great. They fit over my ears rather than crushing them against my head, and the cushions are very comfortable. The sound quality is excellent, and this has actually persuaded one of my friends to buy a pair too. They are a little heavy but they feel exceptionally durable so I don’t mind. The colourway is lovely, really cool design. There are only two buttons and they are both in a place where you can’t easily set them off by accident (unless you lie down on a pillow) and the app is easy to use. I’ve been recommending them to everyone I know.
Verified
More details
Fewer details
Jun 10, 2025
It is good, although the quality of the sound doesn’t compare to some other brands. I bought this because of the sustainability aspect, but am quite disappointed with the lack of customer service. I can’t get the headphones to charge beyond 70%. I sent an email and never heard back. Also tried the chat, but same thing. Think the idea is great, but the company needs to improve customer service
Hello Simone, thanks very much for bringing this to our attention. We’re so sorry to hear about your experience & the wait you're having with our response - we're experiencing busier times on our end. We can see you already created a support request, and we asked our Support team to get back to you as soon as possible. Best, Laura
Verified
More details
Fewer details
May 17, 2025
Sound is perfectly balanced and transparent. I would not recommend these as studio-headphones - everything always sounds beautyful and fascinating. Fit is slightly on the firm side, but the overall build quality feels very sturdy.
Verified
More details
Fewer details
May 12, 2025
The earcups of the Fairbuds are not very deep, making them a bit uncomfortable at first, a thicker foam could help with that and improve the noise cancelling. Nothing to complain about otherwise, the Fairbuds are a bit on the heavy side but they still manage to be more comfortable than my old Bose headset as far as the headband goes. The headset sounds good and works as expected. TYSM for making a bluetooth headset with replaceable batteries, this should absolutely be the industry standard, and the fact that it is not is such a shame. Question: If I were to buy a second battery for my Fairbuds so I can swap the out, would it be possible to charge one battery (out of the headset) while the other one is in use ?
Verified
More details
Fewer details
May 7, 2025
Very easy set up and controls are easy to get the hang of. The cups are big enough to be very comfortable - I can happily wear them for several hours with no problems. No complaints about sound quality although I'm not generally very fussy about that. I don't generally like noise cancelling so also can't say how good that is or isn't compared to other headphones.
Verified
More details
Fewer details
Apr 19, 2025
Although i highly respect the environnement aswell as what you do for it, i am not satisfied with the product. My main issue is that the headphones are really uncomfortable due to their weight, hard clamping, lack of airflow and leather making me sweat. I'm having a hard time listening to music for more than an hour without having head aches and feeling discomfort around my ears. As for the sound quality, there is too much bass and not enough highs, although is somewhat solved this with the equalizer.
Hello Denis, we are sorry to hear about your experience. We can see that our support team offered help with your issue and it was successfully solved. If there’s something we can help with at this point, do not hesitate to let us know. Best, Lore
Verified
More details
Fewer details
Apr 15, 2025
Been using them for two weeks now, very nice so far.
Verified
More details
Fewer details
Apr 11, 2025
I have just have this product for one week cant write about it this soon
Verified
More details
Fewer details
Apr 10, 2025
Nice to wear. Easy to use. Looking good. However the sound is not as good as other headphones in the price range. Noise cancelling on the other hand is superb.
Verified
More details
Fewer details
Feb 25, 2025
They are well manufactured. With regard to comfort, they are not very comfortable after a while using them. Connected to USB sources, the background noise is loud, too loud.
Verified
More details
Fewer details
Jan 23, 2025
Very high quality of the sound. The only downside is that the ear-cushions aren't as soft as expected.
Verified
More details
Fewer details
Jan 21, 2025
Very good headset, a bit pricy if not bought with a fairphone. Very happy with the green color!
Verified
More details
Fewer details
Jan 19, 2025
These are really comfortable - I wear glasses and even after a hour or two I get no discomfort. The quality is great and the value for money is OK. The best thing is that they are fully serviceable and all parts can be replaced by the owner. So I'm looking forward to many years of use as I tend to use quality products for as long as they remain viable - I still use a film camera regularly that is 45 years old and I've had since new.
Verified
More details
Fewer details
Dec 15, 2024
The audio of these headphones is sensational, with its three different modes you can choose whether to listen to what is happening around you or isolate yourself completely. As you can see from the videos on the site about Fairphone, the headphones are completely disassembled and repairable. There is also a very simple but useful application that allows you to further customize the audio for those who have the skills, and also provides useful suggestions for use.
Verified
More details
Fewer details
Nov 1, 2024
The product is simple enough to use easy buy developed enough to not be limited. I really love that every part is replaceble so I'm not afraid to use it often, cause I don't need to buy a new one after one thing is broken.
Verified
More details
Fewer details
Oct 11, 2024
I expected the best, but it was better than expected.
Verified
More details
Fewer details
Sep 29, 2024
The noice-canceling thingie doesn't know what to do with the wind. It doesn't need to be big wind and it gets through badly. Besides that. I love it, but not worth the price.. I would take of 20-50€
Verified
More details
Fewer details
Sep 22, 2024
I absolutely despise the voice feedback. Please give me the option to turn it into little beeps and boops (or rather disable it completely). Also the startup sound pays 1.5 times and it sounds like absolute garbage. Also the headset turns on when I plug it in to charge and I hate it. Also the BT keeps disconnecting/reconnecting to my Fairphone in 2 device mode. So overall I really hate every part of the software (noise canseling is acceptable though) but I'll still keep it and will probably buy from you again because somehow you're the only ones to make repairable stuff. Please put some more care into software, you're not a hardware only company.
Verified
More details
Fewer details
Sep 16, 2024
Nice, comfortable and repairable headphones, noise-cancelling is not the best. Firmware upgrades are possible.
Verified
More details
Fewer details
Sep 12, 2024
Overall nice headphones for the price. Modular and nice looking. ANC leaves a bit to be desired. Wind gives a lot of noise when blowing from certain directions and turning the head will make ambient sounds come through more or less, which can be a bit annoying when listening to music. Other ANC headphones I have used have never had this issue.
Verified
More details
Fewer details
Sep 2, 2024
Good quality, good comfort, it was a bit expensive but I intend to use it as long as possible: it should be well worth it in the long run.
Verified
More details
Fewer details
Aug 12, 2024
The Fairbuds XL feel very solid and fit comfortably. They pair swiftly with my work laptop and mobile phone at the same time, and switching from one to the other is easy and issue-free. I expected noise cancellation to be more noticeable, but I have never tried noise cancellation before, so I cannot compare it to other headsets. Sound quality is good for podcast and meeting content, which is what I use them for. I love that they are completely repairable, and I expect them to last about FOREVER. I use them every day at work, while cooking, when shopping groceries, and they still show no signs of wear. Update december 2024: today after charging them up to 40% i too them to the gym and they would not pair. The On button makes the switch on sound but pressing it again does not make the switch off sound, but again the switch on. I cannot pair them anymore.
Verified
More details
Fewer details
Jul 30, 2024
Wenn man es vergleicht mit dem ANC von anderen Hersteller vorallem Sony können die einfach mehr. Lassen sich halt nicht so einfach Reparieren im Falle des Falles.
Verified
More details
Fewer details
Jul 27, 2024
Any slight touch on the headphones echoes horribly. You can hardy hear anything when it's windy. Expect them to tear off faster than other headphones, althought that is reasonably expected for a modular design.
Hi Jorge, we really appreciate that you took the time to share this feedback with us. We'll make sure to pass it along to our team. If there is anything else we can do at this point, please don't hesitate to contact us. Best, Lara
Verified
More details
Fewer details
Jul 27, 2024
Everything and even more than I expected from the product. Highly recommend!
Verified
More details
Fewer details
Jul 8, 2024
I love my Fairbuds XL headphones. They are comfy and feel very solid and good quality. I also love that they are made in a sustainable way and if anything breaks I can get replacement parts.
Verified
More details
Fewer details
Jul 7, 2024
I love it but it can be a bit hard to turn it on and off sometimes, which is fine considering the good battery The joystick is really great for changing songs and volume, and its comfy and isolates well
Verified
More details
Fewer details
Jul 7, 2024
Very comfortable to wear, execellent audio quality all around, ala in all great value for money
Verified
More details
Fewer details
Jun 30, 2024
These are comfy and good at what they do. They block out noise well, physically, and also the noise cancelling modes work well. If one mode isn't quite right, I switch through the modes and another mode is usually providing the perfect sound balance. I like being able to control the sound profile through the app. (It'd be nice if they had a description of each of the sound profiles.)
Verified
More details
Fewer details
May 27, 2024
dual Bluetooth mode glitches sometimes when connected to two devices, e.g. PC and Phone, listening to music on PC and there are audible glitches whenever notifications arrive to phone (Fairphone 3+). Over extended periods of time of wear needs to be repositioned to avoid discomfort. This wasn't the case with Jabra Evolve 75 that I had before.
Verified
More details
Fewer details
May 9, 2024
Overall good but has some flaws. The vegan leather barely breathes at all, leading to sweaty ears quite quickly. The noise cancelling is good in certain environments, but it's not that great at blocking out voices. Finally, the Bluetooth software stack is not ideal, as it's not fully compatible with all versions of bluez on Linux, but this is not too difficult to work around by installing an older version of bluez. This works well with other headphones, so the Fairbuds XL are certainly doing something a little bit out of spec. Some minor notes: - the lack of a 3.5 mm port is an odd omission. I don't think an adapter is a very nice workaround - the battery remaining reported over the Bluetooth protocol and through the app do not match very well. This is quite confusing. In my phone's Bluetooth settings, it currently says 50% while the app claims 30% - Doing a factory reset on the headphones doesn't actually reset the EQ profile, which is strange
Verified
More details
Fewer details
May 6, 2024
When you buy these headphones, you are making a compromise. You sacrifice quality for fair wages of workers in the supply chain and ecological materials from which the headphones are made, and you gain a product that is easy to repair. Unfortunately, according to my research, the headphones could have a manufacturing defect and are susceptible to breaking the headband base. The ear cups could be a bit larger and versions with different materials could be available. In addition, the fit of the elements could be better, e.g. the headband cover does not fit evenly on the headband. Fairphone is a relatively new brand on the market and still suffers from "childhood problems". An example would be an insufficiently tested firmware update or a poorly selected repair centre (with a lot of bad reviews).
Verified
More details
Fewer details
May 4, 2024
Generally good, but has a few very annoying issues - Short battery life - Very loud sounds for e.g. when switching noise canceling mode. I always have to put them off to change noise canceling due to that. - Noise canceling does not make much of an impact and struggles badly while its windy.
Verified
More details
Fewer details
May 4, 2024
Really nice sound, great design. I did find them a bit heavier than others but soon got used to it
Verified
More details
Fewer details
Mar 24, 2024
It is a bit heavier than expected. Quality of the sound is good.
Verified
More details
Fewer details
Mar 13, 2024
Great for video call. Noise cancelling helps to cut out noise from open space office.
Verified
More details
Fewer details
Feb 23, 2024
Great Headset, I really love using the Fairbuds XL at work, so I wear them for multiple hours a day for the past couple of days. They are quite comfortable and only after hours I put them off for short time. Really nice. A cool thing would be a hardware mute button either at the headphone itself, or at least at the USB-C to 3,5mm-Jack cable. This would mean 5/5 stars for me :)
Verified
More details
Fewer details
Feb 20, 2024
Love that it is fair, of good quality, and that I can repair it myself if necessary.
Verified
More details
Fewer details
Feb 8, 2024
Very happy with these as a replacement for my Bose NC700 which failed after 4 years. I didn't want to buy a third pair from Bose as they didn't last more than 4 years of use. Looking forward to having a longer period of use with my repairable Fairbuds xl
Verified
More details
Fewer details
Feb 6, 2024
I'm a ridiculously heavy user of headphones. As well as regular use, I often sleep in then to cover the noise of a CPAP machine, as well as daytime use. My last three sets of major-brand headphones have all failed at the vertical-axis hinges. These are very comfortable, and wearable for a long time. They don't interfere with sleep. I've repeatedly worn them for entire days. The slight discomfort of not having a vertical-axis rotation of the ear cups is, I think, a very fair compromise. The noise cancelling seems pretty well alongside my previous xm4's. The battery life just blows my previous headphones out of the water. First time I've had a set realistically at >2 days and nights rather than 7-8 hours. Feeling far more robust and solid than other headphones I've used, and the fact that it's repairable means it should massively outlast them. I'm delighted.
Verified
More details
Fewer details
Jan 24, 2024
Well made and comfortable. Ears get a bit hot after a while due to the closed back design. Sound quality is good.
Verified
More details
Fewer details
Jan 8, 2024
Good looking, good sound quality, easy in use. Only discomfort is that the ear buds press a little too hard on the temples of my flasses.
Verified
More details
Fewer details
Jan 3, 2024
Great headphones, they replaced a pair of Sennheiser Momentum 2's that finally failed at the charging socket after much use. These are a very fine replacement!
Verified
More details
Fewer details
Dec 31, 2023
They are perfect. Easy to use, comfortable and the sound is great. The noise cancelling mode is quite great too. As someone who's very sensitive to noise, I wear noise cancelling headphones every time I walk outside of my house and I was afraid that it wouldn't work enough for me, but it's exactly what I was searching for. I feel sufficiently shut off from the world to be at ease, and can rejoice in music peacefully. There's one negative point though : the ear cushions are made from leather and I didn't find this information on the website before my purchase. I made this discovery later, while browsing the fairbuds app. The description lacks clarity about this and it's the only thing, in my view, that prevents Fairbuds from being 100% ethical. Many of us value animal lives just as much as human lives :)
Verified
More details
Fewer details
Dec 26, 2023
Casque très confortable, fonction antibruit performante.
Verified
More details
Fewer details
Dec 1, 2023
Very comfortable and high quality, but I find that the noise cancelling is not the best and that I hear some mild creaking noises through the headphones. The battery life is amazing and simple to repair.
Verified
More details
Fewer details
Nov 17, 2023
Excellent headphones. If you, like me, have large ears, the ear pads might be a bit too small.
Verified
More details
Fewer details
Nov 15, 2023
You don't get all you paid today. I got these to support a company that is giving long turn support
Verified
More details
Fewer details
Nov 15, 2023
nice to hear music, but the mic doesn't work at all
Hello Michael, thanks very much for bringing this to our attention. We’re so sorry to hear about your experience & the wait you're having with our response - we're currently experiencing busier times on our end. We can see you already created a support request, and we asked our Support team to get back to you as soon as possible. Best, Lorena
Verified
More details
Fewer details
Nov 11, 2023
While there are some improvements that I'd like to see, the fact that its so repair friendly, outweigh all the small issues, no other company provides such level of repairability, and I'm confident I could get these headphones lasting 10+ years. I'm using them daily for work calls and for gaming, for which they both do a decent job. Not sure about the microphone, since I use an external one.
Verified
More details
Fewer details
Nov 6, 2023
Sounds good, feels good, should outlast the competition and therefore better value for money for longer.
Verified
More details
Fewer details
Nov 5, 2023
I would have loved to write a better review, but the ANS was extremely weak when used indoor, and I couldn't get the Bluetooth device to be recognized as headphone/headset under Ubuntu 22.04, regardless whether I used pipewire or pulse audio. On the upside the delivery was fast and the return relatively easy.
Hello Henning, we sincerely apologize for the experience you’ve had. We see that you have been already helped by our support team via email. If there's anything else we can do, please do not hesitate to update your support request & we'll help further! Best, Lorena
Verified
More details
Fewer details
Nov 2, 2023
Kind of quiet with Fairphone 5 but works great if connected with PC
Verified
More details
Fewer details
Oct 28, 2023
High sound quality, great comfort, good noise cancelation
Verified
More details
Fewer details
Oct 19, 2023
The mic is useless and the NC takes away hardly anything...
Hello Johannes, thank you for your review. We are truly sorry to hear about the issues you are experiencing with your Fairbuds XL. We’ve sent you an email to get a bit more information so that we can find a fix for you. So keep an eye out for an email from us. Best, Jules
Verified
More details
Fewer details
Oct 16, 2023
Great all around, can be a little heavy on the ears.
Verified
More details
Fewer details
Oct 14, 2023
Comfy headphones. I mainly use them to watch movies and for video call. Active noise cancelling is good. Price is a bit high, but that is the premium you pay for sustainability and for the modular design.
Verified
More details
Fewer details
Oct 8, 2023
Bought these after my Beats Solo 3 broke. I feel that the sound quality in Beats was better. Also for me the comfort of the Beats was better. But for me it is really about long-term investment in electronics and the sustainability aspect. The Fairbuds sound great and are cofortable enough, but if you are looking the best value, then these are not for you
Verified
More details
Fewer details
Oct 1, 2023
Very well made and quite comfortable. Very good sound.
Verified
More details
Fewer details
Oct 1, 2023
good quality, reassuring to know i can replace the ear pieces and battery when needed
Verified
More details
Fewer details
Sep 30, 2023
Good fit, easy to connect to phone and laptop. Easy to use. Noisecancelling is good but could be better
Verified
More details
Fewer details
Sep 28, 2023
Use my Fairbuds on a daily base. For a moment of meditation, enjoy a podcast, to dream away travelling by train.
Verified
More details
Fewer details
Sep 27, 2023
Noise cancelling is depending on direction of source. Everything ahead of you is cancelled well.
Verified
More details
Fewer details
Sep 27, 2023
These headphones are just amazing. The sound is stunning. Very happy
Verified
More details
Fewer details
Sep 25, 2023
Excellent ethical headphones. More expensive, but that's expected when they are ethically sourced/produced.
Verified
More details
Fewer details
Sep 24, 2023
Solid, good sound, easy to use. One tiny feature that would be nice to have and I did not find yet in setting would be to control muting/unmuting the microphone. A solid purchase that seems to be able to serve well for long years.
Verified
More details
Fewer details
Jul 20, 2023
Easy to set up and great sound quality. Noise cancelling works alright. Easy control via joystick. Headphones are quite heavy though but huge advantage is that you can switch out broken pieces yourself! Love that!
Verified
More details
Fewer details
Jul 18, 2023
Love the noise canceling and the audio! I find myself adjusting the headset from time to time because it gets uncomfortable around the ears, maybe I'd need even bigger over ear pieces (or smaller ears).
Verified
More details
Fewer details
Jul 18, 2023
These were a great purchase. We bought them primarily because of the ability to repair and replace parts but the fit and sound quality are excellent, so in the end there was no trade-off :-) Highly recommend and also great to see a company trying to produce electronics that can actually be repaired.
Verified
More details
Fewer details
Jul 16, 2023
While the ANC can't live up to what's claimed on FairPhone's demonstration videos, the overall sound quality is capable of letting me hear all the details in the music I listen to with a good balance between high, mid and low tones. Calls are perfectly audible, both for me and the person on the other end. That some reviews claim the Earbuds XL are too expensive for their value is incorrect. The competition cuts corners which makes their products too cheap.
Verified
More details
Fewer details
Jul 15, 2023
The headphones are excellent quality. The fact that the components and materials used are fairly traded goods is vital as I would not have bought them if they weren't. The listening experience is excellent.
Verified
More details
Fewer details
Jul 15, 2023
I needed some time to evaluate it. All in all, I'm very happy, although It could be more ergonomic when having it on the neck, but my Bose isn't doing better. The Quality is great, but I wish I could turn the speakers 90º to have it take less space. I would also love to have a hard case (as an option) like on my Bose. I'm not sure if the headset could be slightly cheaper because I was happy to spend the money, but some people wouldn't spend so much. I guess maybe you could do a cheaper version with less functionality (not sure). I couldn't find directly the "L" and "R" letters. It wasn't obvious to me what was Left and Right. Also in some cases you can touch the wheel/jog dial without willing to... All in all THANKS for the amazing product. This is why I'm giving a 5-Star in general ;-)
Verified
More details
Fewer details
Jul 14, 2023
Superb build and sound quality! A little heavy (and tight) for my liking. But they look and sound phenomenal, and the price is worth knowing its supporting a better and fairer world for everyone.
Verified
More details
Fewer details
Jul 12, 2023
It is a very well designed and built product with the possibility of being repaired by me if needed. I'm very satisfied with it. Hopefully the app will be updated with more featured in the future.
Verified
More details
Fewer details
Jul 1, 2023
Color, comfort & quality are great. Love my Fairbuds XL.
Verified
More details
Fewer details
Jun 29, 2023
Good quality wireless earphones that are easily repairable. We need more companies like Fairphone that care about making products that last instead of creating more e-waste.
Verified
More details
Fewer details
Jun 29, 2023
I am higly disapointed, i knew i was buying the product for it's sustenability, but i was expecting it to be all around way better as i won't be using it. First, it's not confortable, it get warm quickly and have barely any breathability. The closed back design, unlike other, make it quite echoy, and any rubbing from your hair or head wear on the plastic will be quite noticeable. The default noise floor is very hard to determine as the device minimal volume is crazy high. On my galaxy note 9 and my laptop the headset won't emit any sound under 9% of volume, like if it was on mute. Then it's immediately slightly higher than my normal confortable listening level. That mean no podcast or calm music late at night for me. (Or with a jack, no volume issue with it, but then why buying this) Sound quality, outside of the mecanical noise, is ok to me, i'm no audiophile. The "sound profile" are very weird... city name, not very explicit and requiere the app to switch ... give user an EQ, not what ever this is. Then ANC... It's a feature on the box... but it's' quite the downgrade ! It does help a bit with whooshing sound like AC, but that's it, it does nothing for noise, talking, city noise like car... and it bring a very high and noticeable hiss or noize. Sadly there are no way to have it disable all the time and it will be back on the next time you turn the headset on. Mic isn't good from what other tell me but it could be a bluetooth generality as i am comming from a modmymic. Finaly, i wanted to order a replacement battery at the same time as the headset to avoid another shipping co2 cost, but they don't have itnon their shop... I will now have to debate betweend the carbon cost of returning it (will it be repackaged or go to the bin ?) Or having it stay in a box for ever...
Hello Guillaume, thanks very much for sharing these suggestions and bringing this to our attention. We’re so sorry to hear about your experience. We can see you are currently being assisted by our support team via e-mail. Best, Lorena
Verified
More details
Fewer details
Jun 26, 2023
Excellent product. I know of the company and policy to allow you to fix things so snappped this up as I needed a new headset for calls etc. But it's far exceeded my expectations in terms of quality of build and the sound. The noise cancelling is excellent to. Very happy customer.
Verified
More details
Fewer details
Jun 25, 2023
Great concept, fully repairable for a competitive price.
Verified
More details
Fewer details
Jun 22, 2023
The Fairbuds XL headphones are a perfect companion to the Fairphone 4. They deliver high-quality sound and are made from recycled materials, further showcasing Fairphone's dedication to sustainability. These wireless headphones fit comfortably in the ear and offer a good battery life, allowing us to enjoy our favorite music uninterrupted.
Verified
More details
Fewer details
Jun 19, 2023
The Earphones look awesome and work well with the app and by using the controls on the ear patch. However, I had to send them back because I wasn't pleased at all with the modes for ambient sound (voice through) and active noise cancelling. Both modes are useless outside if there is only the slightest wind. I also tried them in office where I intended to use the noise cancelling for. There was still a lot of ambient sound coming through (keyboard clicks, collegues on telephone calls etc.). The "normal" headphone mode sounded good but I have the feeling that the price is way too high if you can only use them without the two other modes.
Hello Johannes, thank you for posting a review. We’re sorry to hear that your experience with the Fairbuds XL was not as good as expected. We’ll make sure to pass your feedback along to our team. Best, Lorena
Verified
More details
Fewer details
Jun 19, 2023
The headphones are overall pretty good, not the best I've used but they're decent. The music is clear, they look great. I think the comfort will increase as I get used to using noise reducing over ear headphones. The only downside is when they're connected to two devices (the main reason I bought these ones), when there is a notification on one device while listening to music on the other, there's a brief, awful crackly noise before resuming music. A bit annoying, I don't care a huge amount about it but I know it would bother some people too much
  • All Languages
  • English
  • Deutsch
  • Français
  • Nederlands
  • Most recent
  • Oldest
  • Großartiger Sound. Langlebig designt.
  • Aktive Geräuschunterdrückung
  • Akkulaufzeit von bis zu 30 Stunden
  • Verbindung über Bluetooth oder USB-C
€249.00 -0% Save €0
Oder zahle in 6 Raten mit
Out of stock Coming soon. Be the first to know when it's available Coming soon JETZT KAUFEN notify me We'll keep you posted notify me Lieferung: 2 - 5 tage (ab €3.95) 3-Jahre Garantie 14 Tage kostenlos testen Händler suchen
This item is out of stock
Invalid email address
notify me
Fairbuds XL Headphones is coming soon.
notify me
Fairbuds XL Headphones was added to cart.
Extra accessories for your Fairbuds XL Headphones
Fairbuds XL Headphones USB-C - mini jack 3.5mm Cable
This variant is out of stock
notify me
We will notify when it’s back in stock
Coming soon. Be the first to know when this color is available
Enter your email address and we will notify you when it’s available.
notify me
We will notify when it's available
• Fast 240W charging
• Three-year warranty
• Universal compatibility
1 meter
2.5 meters
notify me
notify me
30W USB-C Fast Charger
• Quick 30W charging
notify me
notify me
Neue dynamische 40-mm-Treiber in Lautsprechern mit verbesserter Abstimmung
Fortschrittliche Geräuschunterdrückung für besseren Klang, wo immer du bist
Neues Materialdesign für mehr Komfort und Tragbarkeit
30 Stunden Hörgenuss
  • Modular mit leicht austauschbaren Teilen
  • Jetzt mit automatischer Abschaltfunktion
  • Nahtlose Dual-Point-Konnektivität
Du musst den Akku austauschen?
Tausche sie einfach selbst schnell aus!
Optimal abgestimmt
  • Ausgewogeneres Stereo-Klangbild
    Natürliche Tiefen, Mitten und Höhen mit einem flacheren, neutralen Klangprofil, das du nach Belieben anpassen kannst.
  • Überragende Klangleistung
    Unterstützt aptX High Definition für 24-Bit-Wireless-Sound, der rein und kraftvoll ist.
  • Drahtlos oder kabelgebunden
    Schließe das Gerät mit einem USB-C-Kabel an, um es batterielos zu nutzen. Oder verbinde es kabellos über Bluetooth. Du entscheidest.
  • Klare Sprach- und Videoanrufe
    Die Dual-Mics und intelligente Geräuschunterdrückung filtern alles raus, was stört.
Technische Spezifikationen
Forest Grün
Horizon Schwarz
Audioleistung
  • Dynamische 40mm Treiber
  • Frequenzbereich: 20 Hz – 20 kHz (deckt den gesamten Hörbereich des Menschen ab)
  • Treiberimpedanz: 32 Ohm (kompatibel mit den meisten Geräten)
  • Empfindlichkeit: 99±2 dB bei 1 kHz (maximale Lautstärke bei minimaler Leistung)
  • Codec-Support: SBC, AAC, aptX HD
  • Aktive Geräuschunterdrückung (ANC)
  • Ambient Mode verfügbar
  • Mikrofone: Sechs Mikrofone (2 links, 4 rechts)
Akku & Laden
  • Bis zu 30 Stunden Wiedergabe (ANC aus)
  • Bis zu 26 Stunden Wiedergabe (ANC an)
  • 50 % Ladung in 15 Minuten (Schnellladen für 15 Stunden Wiedergabe)
  • USB-C-Ladeanschluss
  • Akkulebensdauer: 500+ Ladezyklen (behält nach 500 vollständigen Ladungen 80 % Kapazität)
  • Austauschbarer Akku
Konnektivität
  • Bluetooth 5.1 mit Dual-Multipoint (gleichzeitige Verbindung mit zwei Geräten)
  • USB-C-Port für kabelgebundenes Hören
  • Kabellose Reichweite: bis zu 10 Meter
  • Kompatible Sprachassistenten: Google Assistant, Amazon Alexa und Apple Siri
Physische Spezifikationen
  • Gewicht: 330 g
  • Abmessungen: 190 mm × 180 mm × 70 mm
  • Faltbares Design für hohe Portabilität
  • Verstellbarer Kopfbügel (für Kopfgrößen von S bis XXL)
  • Drehbare Ohrmuscheln (90°) – flach faltbar für einfachen Transport
Garantie
  • 2 Jahre Standard + 1 Jahr verlängerbar (bei Registrierung)
Bewertungen & Zertifizierungen
  • LONGTIME®-zertifiziert für Reparierbarkeit und Langlebigkeit
  • IP54-zertifiziert gegen Staub und Feuchtigkeit
Materialien & Langlebigkeit
  • Netzgewebe im Kopfbügel
  • Piqué-Gewebe in den Ohrpolstern
  • PU-Leder in Kopfbügel und Ohrpolstern
  • Modulares Design mit neun austauschbaren Ersatzteilen
  • 100 % recycelte Seltenerdmetalle in den Magneten
  • 100 % recyceltes Zinn in der Lötpaste
  • 80 % recycelte Kunststoffe
  • 92 % recyceltes Aluminium
  • 100 % faires Kobalt, Kupfer und Silber (über Credits)
  • Fairtrade-Gold in der Lieferkette integriert
  • Reiseetui aus recycelten Stoffen
  • 100 % Grünstrom in der Montage
Bedienung & Funktionen
  • Joystick und ANC-Taste
  • Automatische Abschaltung
  • Anpassbarer Equalizer über die Fairbuds App
Dein Sound, neu definiert.
Neue 40-mm-Treiber, stärkere Magnete und eine verfeinerte Papiermembran sorgen für sattere Bässe sowie präzise Mitten und Höhen.
Schalte den Lärm aus. Wann immer du möchtest.
Mit unserer fortschrittlichen Geräuschunterdrückungstechnologie kannst du zwischen dem aktiven Modus und dem Ambient-Mode wechseln. Du entscheidest, wann du die Welt hereinlassen und wann du sie draußen lassen möchtest.
Verbesserte Smartphone-App für noch mehr Kontrolle
Die neue Fairbuds-App bietet neue Voreinstellungen und anpassbare EQ-Einstellungen für die verbesserten Fairbuds XL.
Entwickelt für eine längere Lebensdauer
  • Drei Jahre Garantie
    Standardmäßige zweijährige Garantie mit einer kostenlosen Verlängerung um ein Jahr
  • Wetterfestes Design
    IP54-zertifiziert für leichte Regenschauer und intensive Fitness-Sessions.
    Tausche den Akku in wenigen Minuten gegen einen neuen aus.
Zertifiziert mit dem LONGTIME®-Label
Die Fairbuds XL sind das weltweit einzige LONGTIME®-zertifizierte Audioprodukt für Verbraucher, das für seine Langlebigkeit, Strapazierfähigkeit und Reparierbarkeit anerkannt ist.
ZERTIFIZIERUNG
Modulares Design für einfache Wartung
Nichts verklebt, einfache Schrauben. Du kannst die Fairbuds XL mit einem Schraubenzieher in wenigen Minuten auseinanderbauen und bei Bedarf bis zu neun Ersatzteile austauschen.
Austauschbarer Akku
Fairer denn je
  • 100 % erneuerbare Energie bei der Montage
  • 100 % Elektromüll-neutral
  • 92 % recyceltes Aluminium, 100 % recyceltes Zinn in der Lötpaste und 100 % recycelte seltene Erden in den Magneten
Die Unternehmenszertifizierungen von Fairphone umfassen
Fairbuds XL full impact
Lass uns über Impact sprechen
Überragender Klang. Nachhaltiges Design.
Seit unserem Einstieg in die kabellose Audiowelt verfolgen wir das Ziel, echte Langlebigkeit und Nachhaltigkeit ins Audiosegment zu bringen. Mit den verbesserten Fairbuds XL kombinieren wir Premium-Sound mit modularer Reparierbarkeit und einer verantwortungsvollen, ethischen Lieferkette—fair für Mensch und Planet.
Langlebig designt
Unsere Fairbuds XL sind auf Langlebigkeit ausgelegt: mit modularer Architektur, leicht austauschbaren Komponenten und langfristiger Softwareunterstützung. Dieser Ansatz reduziert Elektroschrott und verlängert den Produktlebenszyklus—für Kopfhörer, die Jahre halten, nicht Monate.
  • Drei Jahre Garantie: 2-jährige Standardgarantie + 1 Jahr kostenlose Garantieverlängerung
Hergestellt mit mehr fairen und recycelten Materialien als je zuvor
Wir kompensieren unseren Materialeinsatz über verantwortungsvolle Credit-Mechanismen und integrieren zudem Fairtrade Gold in unsere Lieferkette. Zum ersten Mal verwenden wir auch recycelte Seltenerdmetalle in unseren Magneten.
  • 92 % recyceltes Aluminium (nach Gesamtgewicht)
  • Über 80 % recycelte Kunststoffe (nach Gesamtgewicht)
  • 100 % faires Kupfer (über Cobalt Credits)
  • 100 % faires Gold (via Fairtrade Gold & Fairmined-Credits)
  • 100 % Fairmined-Silber (über Credits)
  • Recycelte Stoffe im Reiseetui
Besser für Mensch und Umwelt
Negativen Einfluss auf die Umwelt minimieren. Positiven Einfluss auf Fabrik- und Minenarbeiter maximieren. Genau darum geht es.
Hergestellt unter faireren Arbeitsbedingungen
Die Endmontage erfolgt in Fabriken, die existenzsichernde Löhne, Mitarbeiterwohlbefinden und Umweltmaßnahmen unterstützen. Wir stellen faire Arbeitsbedingungen über die gesamte Lieferkette hinweg sicher.
Mit 100 % erneuerbarer Energie gefertigt
Unsere Fertigung nutzt zu 100 % erneuerbare Energie—für geringere Emissionen und messbare Klimavorteile im Vergleich zu herkömmlicher Audioproduktion.
Klimabewusst
Wir tun alles, um die Klimawirkung der neuen Fairbuds XL zu minimieren: durch Vermeiden und Reduzieren von Emissionen in der Produktion und durch Beiträge zu Klimaprojekten.
Zusammenarbeit mit Lieferanten
Um unseren CO₂-Fußabdruck wirklich zu senken, arbeiten wir eng mit unseren Lieferpartnern zusammen. Wir setzen klare Klimaziele und verwenden recycelte Rohstoffe – darunter Aluminium, Magnesium, Seltene Erden, Zinn, Nickel, Zink, Kupfer, Kunststoffe und Indium.
Wir investieren in den Planeten
Die verbleibenden Emissionen der Fairbuds XL kompensieren wir durch Gold-Standard-Projekte, die CO₂ senken und gleichzeitig lokale Communities fördern.
Fairtrade Gold
Wir sind das erste und einzige Elektronik-Unternehmen, das Fairtrade Gold in seine Kopfhörer-Lieferkette integriert.
Fairtrade Gold
Im Lieferumfang
  • Die neuen Fairbuds XL
  • Schnellstartanleitung + Sicherheits- und Garantieinformationen
  • Reise-Etui
Keine unnötigen Kabel oder Zubehörteile, die herumliegen. Nur das Nötigste, um Elektroschrott zu reduzieren.
Teste jetzt die neuen Fairbuds XL
Besserer Klang. Besseres Design. In jeder Hinsicht besser für dich.
  • 30 Stunden ununterbrochene Betriebszeit
  • Erweiterte Rauschunterdrückungsmodi
  • Modulares Design mit austauschbarem Akku
Forest Grün
Horizon Schwarz
0.00 €249
FAQ
Was ist an diesen Fairbuds XL im Vergleich zu den ursprünglichen neu?
Die neuen Fairbuds XL bieten deutlich besseren Sound, komfortablere Materialien und noch mehr Nachhaltigkeit und das zum gleichen Preis. Es verfügt außerdem über eine automatische Abschaltfunktion nach 30 Minuten Inaktivität, wenn die aktive Geräuschunterdrückung (ANC) ausgeschaltet ist.
Sollen die neuen Kopfhörer das alte Modell ersetzen?
Ganz und gar nicht, ganz im Gegenteil. Du kannst den Sound deiner Fairbuds XL (2023) in wenigen Minuten upgraden. Einfach die Lautsprechereinheiten austauschen und fertig. Andere Komponenten bleiben wie gewohnt austauschbar. Dieses Upgrade stärkt die Langlebigkeit beider Versionen, anstatt die eine durch die andere zu ersetzen.
Kann ich die Ersatzteile der neuen Fairbuds XL in meine alten Fairbuds XL einsetzen?
Ja! Wir haben die neuen Fairbuds XL so konzipiert, dass sämtliche Ersatzteile in beide Modelle passen.
Was genau wurde bei der Audioqualität verbessert?
Die neuen dynamischen 40-Millimeter-Treiber und die feinere Abstimmung schaffen einen natürlicheren und ausgewogeneren Sound. Mit klareren Höhen, weicheren Mitten und kontrollierten Tiefen. Die neue Abstimmung wurde speziell für die aufgerüsteten Treiber kalibriert und sorgt für eine spürbare Verbesserung beim täglichen Hören.
Die Kopfhörer sollen zu 50 % aus fairen und recycelten Materialien sein. Was bedeutet das?
In den Lautsprechermagneten steckt zu 100 Prozent recyceltes Material aus Seltenen Erden, dazu kommen über 90 Prozent recyceltes Aluminium und über 80 Prozent recycelte Kunststoffe. Kupfer, Kobalt, Silber und Gold in den Fairbuds XL werden über Mineral Verified Credits erfasst, damit die gleiche Menge unter faireren und nachhaltigeren Bedingungen gefördert wird. Das senkt die Umweltbelastung und unterstützt sichere und bessere Arbeitsbedingungen entlang der Lieferkette.
Verkürzen nachhaltige Materialien die Haltbarkeit?
Nein. Alle recycelten und fair abgebauten Materialien erfüllen dieselben technischen und sicherheitstechnischen Anforderungen wie herkömmliche Materialien. Die neuen Fairbuds XL wurden durch das unabhängige LONGTIME-Label auf ihre Langlebigkeit getestet und zertifiziert und bestehen wie gewohnt alle unsere hauseigenen, strengen Tests.
Was macht die Fairbuds XL noch klimabewusster als die Vorgänger?
Die Kopfhörer werden zu 100 % mit erneuerbaren Energien hergestellt und sind zu 100 % elektromüllneutral. Das bedeutet, dass für jedes verkaufte Gerät die entsprechende Menge an Elektromüll gesammelt und recycelt wird. Dies baut auf den Verbesserungen des ursprünglichen Modells auf. Zudem enthalten sie, wie oben erwähnt, ca. 50 % faire und recycelte Materialien.
Kann ich die Fairbuds XL mit einem 3,5-mm-Klinkenadapter verwenden?
Fairbuds XL Modelle vergleichen
Fairbuds XL NEU
0.00 €249
Fairbuds XL (2023)
0.00 €249
Lautsprecher-Treiber
Neue and verbesserte 40-mm-Treiber
40-mm-Treiber
Farben
Forest Grün Horizon Schwarz
Grün Schwarz
Materialien
Netzgewebe im Kopfbügel Piqué-Gewebe in den Ohrpolstern
Abschaltautomatik
Ja (30 Minuten)
Nein
Garantieumfang
Drei Jahre
(2 Jahre Standardgarantie + 1 Jahr Garantieverlängerung)
Zwei Jahre
(2 Jahre Standardgarantie)
Nachhaltigkeit
100 % recycelte seltene Erden in Magneten 100 % erneuerbare Energie bei der Montage LONGTIME®-zertifiziert
